The specified IP socket option was not set correctly on the socket used to send an echo reply. This may result in the echo reply not being sent, delivered, or processed correctly.
There is no workaround; however, this problem is usually transient and should not persist.
Warning
Failed to set IP sockopt (%opt%) on echo reply socket %sck%.
| Name | Type |
| opt | String |
| sck | sInt |
